I have an application (a tube with parts in it) which needs a certain static pressure in it in order to contain a sustainable air flow. Unfortunately the fan I wanted to use in a push-configuration is not able to create this pressure. Thus I thought that I could install another fan with a higher cfm at the end of the tube (in pull-configuration), and thereby increasing the static pressure? Would that be useful, or is there another way to increase the static pressure in the tube? Schematic is: enter image description here
Neither F1 or F2 are able to provide the necessary static pressure alone.
  • $\begingroup$ I am not so sure about your configuration, could you add a sketch? What happens if you only use the other fan? $\endgroup$
    – rul30
    Oct 10, 2015 at 15:02
  • $\begingroup$ I hope this drawing is enough, if not, please note. $\endgroup$
    – arc_lupus
    Oct 10, 2015 at 15:12
  • $\begingroup$ Thanks. Why do you say the blowers need to provide static pressure? Wouldn't F2 reduce the pressure in the tube? Anyhow, be reducing the pressure in the tube F1 is more likely to have a higher flow rate $\endgroup$
    – rul30
    Oct 10, 2015 at 15:14
  • $\begingroup$ If F2 is blowing outwards, and F1 inwards, then the static pressure during the tube (inside are obstacles) should be higher, afaik. $\endgroup$
    – arc_lupus
    Oct 10, 2015 at 15:21
  • $\begingroup$ actually you only need a "high" static pressure in the tube with a single fan set-up because this is what will make the air flow through the pipe. At the end of the pipe the air will have the ambient pressure again. When you have to much pressure loss inside the pipe caused by obstacles you have a very low/no air flow. With the additional fan at the end of the pipe the pressure inside of the pipe can be lower than the ambient pressure, because F2 will rise the pressure enough so that the air can exit the tube. $\endgroup$
    – rul30
    Oct 10, 2015 at 15:35
In order to get the air through the pipe, the pressure rise of the first fan has to be so high, that the pressure-loss within the tube is compensated.
Since your first fan (F1) is not powerful enough you can add a second fan (F2) to rise the pressure at the end of the pipe to ambient pressure, or use a more powerful fan (F3) instead.
setch
The sketch shows the static pressure on the y-axis and the tube at the x-axis
