A question asked about the necessary curing pressures for a composite resin in the autoclave. Looking through the corresponding datasheet (HexPly F155), I'm confused:
Cure Procedure
  1. Apply vacuum of 22 inches (74 kPa) Hg minimum.
  2. Apply 85 + 15 – 0 psig (586 + 103 – 0 kPa) pressure for laminates.
  3. Apply 45 + 15 – 0 psig (310 + 103 – 0 kPa) pressure for sandwich.
  4. Vent vacuum bag to atmosphere when pressure reaches 20 psi (138 kPa).
  5. During cool-down when the part temperature falls below 140°F (60°C), pressure can be released and the test panel removed from the autoclave and debagged.
The first step is clear, but not the next steps, for instance 85 + 15 – 0 psig (586 + 103 – 0 kPa) is causing me a headache and I can't make sense of it.
I'd guess that one is the external positive pressure and the other is negative vacuum pressure under the sheet, but I couldn't for instance have a 103 kPa vacuum.
Cure Procedure
I believe Steps #2 and #3 are providing you a tolerance for the applied pressure.
So, for Step #2, it's telling you to apply 85 psig. You can go +15 psig higher (for a total of 100 psig) but should not go lower than 85 psig. Normally, this is written as $85^{+15}_{-0}$ psig or 85 +15/-0 psig.
For Step #3, apply 45 psig, with an upward tolerance of +15 psig (total 60 psig) but go no lower than 45 psig total pressure. Normally, this is written as $45^{+15}_{-0}$ psig or 45 +15/-0 psig.
    $\begingroup$ That is also the way that I read it. It's poorly written though, usually double-sided tolerances are written as $85^{+15}_{-0}$ psig. $\endgroup$ Oct 9, 2015 at 15:14
    $\begingroup$ If nothing else, I'd expect to see "85 +15/-0 psig" when the super- and subscripting is not possible. $\endgroup$ Oct 9, 2015 at 15:20
  • $\begingroup$ I would assume the datasheet was written by someone who is not technical-minded. Wouldn't be the first time. Also, added both of your tolerance notations to my Answer. $\endgroup$
    – grfrazee
    Oct 9, 2015 at 15:26
