I want to model a problem that the theory behind is in the "Coupled Pore Fluid Flow and Stress Analysis" context that there is in the ABAQUS online documentation, version 2022. The link to the documentation is this [ Coupled Pore Fluid Flow and Stress Analysis ].
As you can see in the doc in the input file template it is mentioned that:
*SPECIFIC HEAT, PORE FLUID
Data lines to define specific heat of the permeating fluid if transient heat
As you can see, specific heat is defined for the pore fluid. How could I define the specific heat for the pore fluid in ABAQUS CAE? Because there isn't any module or anything like that for defining the specific heat of the pore fluid in the Property Module of the ABAQUS CAE.
  • $\begingroup$ the link requires a login $\endgroup$
    – jsotola
    Nov 11, 2023 at 17:04
