They've printed jet engines with it that work after polishing. So how is the accuracy measured and how accurate is the DMLS process? I can't find the required info anywhere.
$\begingroup$ This question is well-suited for the 3D Printing and Rapid Prototyping SE site. It is in the commitment phase on Area 51 right now. $\endgroup$– Chris MuellerOct 9, 2015 at 20:15
1 Answer
Accuracy will vary a lot depending on what you are interested in.
At the simplest level you are limited by the layer thickness, which is in the $20-100~\mu m$ range. This places a limit on the accuracy of the dimensions that can be achieved in the z direction. Theoretically you can achieve very high accuracy in x and y, but in reality you are limited by the roughness of the the part.
Indeed, the real problem with most of these additive technologies is that the resulting surfaces are very rough, hence why polishing is needed to finish the surface. I don't know for DMLS specifically, but for related methods, such as SLM, $30~\mu m$ roughness would not be bad. Generally, the roughness is highest where the part is angled with respect to the layers as you then can get additional effects from going over steps.
$\begingroup$ I took some measurements and if all works out, my printer will have a 30 micrometer layer thickness assuming the melted material doesn't spread out. L = .8mm per step (un-geared), and L = .8mm / 27 (geared 1:27) = .03mm = 30 um. The nozzle diameter will be .1mm which is the smallest drill bit I could find. $\endgroup$ Oct 13, 2015 at 19:07
