I ran a CFD simulation of Mach=0.85 flow over an aerofoil and noted that my Cp (coefficient of pressure) plot over predicts the shockwave in comparison to experimental data?
Can someone please explain why?
Parameters: Turbulence model: k-w sst Discretisation: third order
  • $\begingroup$ Experimental is accurate for the actual conditions, models have assumptions that affect accuracy. Got told of a wing that was subjected to experimental stress loading - failed within about 5cm of the predicted failure point. Which was more accurate?? $\endgroup$
    Oct 31, 2023 at 12:36
Were the experimental data adjusted for wind tunnel conditions? Wind tunnel experiment have different boundary conditions than 2-d airfoil in cfd.
