My professor asked me to make the orthographic projection of this object with the third angle rule, but the object has an oblique/slanted surface. Does it require an auxiliary view too?
I would think yes to make the dimensions of the dovetail slot clear.
Your questions is: "Does it require an auxilliary view also?"
It's not part of the assignment as written. I would ask the lecturer/teacher about this question first. I strongly suspect that they only want one of the 2 views but stating the less obvious is to show your calculation of the 60 deg angle measures using trignometry. The horizontal distance being lengthcos(60) and vertical distance being lengthsin(60) with the understanding that arctan 60=Vertical/Horizontal. Going the extra distance without time constraints only pushes your mark higher.
does an auxiliary view add new information?
