I am designing a system that is constantly flowing compressed air through a valve which is open to the atmosphere. I would like to size a heater to keep the valve at a constant temperature and prevent it from freezing due to the heat loss from the fluid expanding through the valve, is there an approximation I can use to estimate the heat loss?
As an example, the air is flowing at 0.01 kg/s, expanding from 24.1 MPa / 60 C to ambient conditions (0.1 MPa, 20C)
