I have a 50 year old forged magnesium alloy wheel apparently marked AS161, which I have been led to believe is AS1.61 - not dissimilar to this picture here. So I assume 1.6% aluminium and 1% silicone - sound reasonable? A spoke is cracked and I'd like to weld it. What would be the correct heat treatment for this alloy, to relieve welding-related stresses?
I've seen circa 340 Celcius for annealling to relieve stresses. And I've seen holding at 175 Celcius for circa 24 hours to harden. Then I'm aware that the magnesium will already have naturally hardened over time. And I've seen a specific recommendation for welding stress relief, to hold for fifteen minutes to one hour at between 130 to 260 Celcius, depending on the alloy composition, but I don't have a recommendation for this specific alloy.
I'm aware magnesium burns in water.
  • $\begingroup$ What's your filler? $\endgroup$
    – Abel
    Commented Sep 6, 2023 at 13:19
  • $\begingroup$ @Abel that I don't know yet either. I could do with confirming my interpretation of the AS161 alloy stamping is correct first, as that would affect it. But AZ101A is supposed to be versatile I think. It would introduce more aluminium and won't add a lot of zinc to the weld which would cause brittleness. $\endgroup$ Commented Sep 6, 2023 at 13:58
