Every type of fuel cell has a catalyst and an electrolyte to carry electrons between the cathode and anode. What I don't understand is how the electrolyte is stored in a Alkaline Fuel Cell. In essence, is the electrolyte stored as a liquid in a tank with the electrodes at either end of the fuel cell, or in some sort of sponge that is soaked in the electrolyte and then periodically re-wet with additional electrolyte?
How is the electrolyte stored in an Alkaline Fuel Cell?
After some research of my own, I've found that Alkaline fuel cells tend to store the electrolyte as a liquid in a very thin layer (around 1.2-1.7mm in thickness) which can have some sort of solid polymer matrix or other shape to maintain its shape and structure.
I also found that the electrolyte is normally a free-flowing liquid, so a pump and reservoir is often used to circulate the electrolyte.
Reference 1 - https://arrow.tudublin.ie/cgi/viewcontent.cgi?article=1027&context=engscheleart2
