I'd like help coming up with a simple brushed DC motor-powered mechanism that achieves the following.
- Rotating the motor clockwise causes a linear mechanism (a pin) to arrive at position A
- Further clockwise rotation does nothing to change the pin position and does not damage the system.
- Rotating the motor counter-clockwise causes a linear mechanism (a pin) to arrive at position B
- Removing power from the motor does not change the position of the pin
