I am designing a machine that will feature a multi-piece crankshaft. The crankshaft sections will come apart in order to slide the crankshaft through some mounted ball bearings. The fit I am aiming for is similar to the fit of a drive sprocket on a shaft. The flat crankshaft sections will slip onto the shaft sections and be secured by a bolt and two keyways.
After doing some research on wikipedia, I found the following fit:
Similar fit - Negligible clearance or interference fit which can be assembled or disassembled with a rubber mallet, e.g., hubs, gears, pulleys, bushes, bearings - H7/j6
I am also considering an H7/k6
This fit sounds like a good choice for a crankshaft section, since a gear or pulley must transmit power/torque in a similar fashion.
Here are some pictures of my system
