Recently, I noticed some strange objects attached to the cables of a bridge (in Münster, Germany):
What are they called and what is their purpose? They don't look like connectors of any kind nor do they seem to provide any support to the cables.
From a website of a manufacturer of a similarly shaped item, this may be a variation on a Stockbridge Damper:
Note that the shapes of these types of devices vary from application to application and are likely to be tuned for each specific installation. The "world of wiki" provides a summary:
Stockbridge damper is a tuned mass damper used to suppress wind-induced vibrations on slender structures such as overhead power lines, long cantilevered signs and cable-stayed bridges. The dumbbell-shaped device consists of two masses at the ends of a short length of cable or flexible rod, which is clamped at its middle to the main cable. The damper is designed to dissipate the energy of oscillations in the main cable to an acceptable level.
Perhaps a pendulum detuner? Used to control low-frequency vibration coupled to the road bed (rather than high-frequency aolean vibration controlled by stockbridge dampers or spiral vibration dampers).
The bridge is slightly unusual (and slightly modern). Dampers may have been added after testing after original construction.
