I know that there are 7 general purpose registers( A,B,C,D,E,H and L). I am told that F is missing as F is said to be corresponding to flag register but I am not able to understand why they left out G. This has nothing to do with anything technical just a curiosity.
    $\begingroup$ Probably because G looks like C. Would avoid confusion on handwritten code. $\endgroup$ May 13, 2023 at 23:48
  • $\begingroup$ it looks like the 8-bit registers are paired ... A&flags, BC, DE ... FG would also be a pair, but F is paired with A, so no room for G $\endgroup$
    – jsotola
    May 14, 2023 at 2:38
Wikipedia's Intel 8085 article suggests to me that H and L are not the same type of register. Instead H and L appear to refer to the High and Low bytes of the 16-bit indirect address.
Main registers
A   Flags   Program Status Word
B   C
D   E
H   L       (indirect address)
  • $\begingroup$ Yes thanks. I think it makes quite a lot of sense to leave G in this case. $\endgroup$ May 16, 2023 at 21:16
  • $\begingroup$ ...and there are a few other instructions that use H and L together as if they were a single 16-bit register, such as LHLD and SHLD. $\endgroup$ May 17, 2023 at 16:09
