Disclaimer:
I am very new to the field of mechanics, my background is in electrical engineering. I apologize in advance if anything is horribly wrong.
My references are:
"First Course in FEM, 4th Edition" by Daryl L Logan
"Theory of Elasticity, 3rd Edition" by S. Timoshenko and J.N. Goodier
Problem Statement
Let's say I have some three dimensional body which undergoes a deformation due to an internal stress profile. Call the undeformed state $ X $ and the deformed state $ X' $.
Assume that the undeformed state $ X $ has some internal stress profile and this stress profile is not in equilibrium. Call this initial stress profile $ S $. As time proceeds, the body relaxes until equilibrium is achieved. The deformed body in state $ X' $ ends up with some resulting stress profile $ S' $. A stress profile is constituted by a stress tensor at every point within the body.
Let's say that I have displacement equations describing the deformation. Concretely, I have three equations $ x' = d_1(x, y, z) $, $ y' = d_2(x, y, z) $, and $ z' = d_3(x, y, z) $. These fully describe how a point $ (x, y, z) $ moves to $ (x', y', z') $ under the deformation.
My primary goal is to use the displacement functions to estimate the stress tensor at every point in $ X $ which resulted in the observed deformation.
Here is my current approach:
Assuming small strain, we can relate the displacement equations to the entries in the strain tensors at every point. In particular, we know that $ \epsilon_x (x, y, z) = \frac{\partial d_1}{\partial x} (x, y, z) $, $ \epsilon_y (x, y, z) = \frac{\partial d_2}{\partial y} (x, y, z) $, etc.
Assuming linear elastic behavior, the stress and strain tensors at any point are linearly related. Thus we can say that $ \sigma = D \epsilon $ for some matrix $ D $. We can then use the strain tensors at every point, generated via the technique in step 1, to compute the stress tensors at every point which resulted in the observed deformation.
Questions
I'm not sure that this technique will produce a reasonable estimate of the stress tensors which caused the deformation. Step 2 relies on linear elasticity, but the deformation from $ X $ to $ X' $ is plastic. Do people think that this approach has any hope of estimating the stress profile of $ X $? Might it only produce reasonable results if the deformation is small?
If we knew the strain tensor, $ \epsilon $, at every point in a body which underwent a deformation, is there anything wrong with using $ \sigma = D \epsilon $ to recover the stress tensor, $ \sigma $, which caused the observed deformation?
Are there existing techniques to recover the stress state which resulted in an observed deformation? I've looked around and haven't found anything useful.
Edits: Cleaned up the assumptions necessary for the 2 step process.
