I'm writing an essay which partly includes writing about the Reynolds stress model where the dissipation term $\varepsilon_{ij}$ is assumed to be isotropic (since dissipation mostly occurs at small scale turbulence, which is isotropic). More specific, the dissipation term is modelled as
$$\varepsilon_{ij} = \frac{2}{3}\varepsilon\delta_{ij},$$
where $\delta_{ij}$ is the Kronecker delta and $\varepsilon$ is the dissipation term from the $k$ equation (ie turbulent kinetic energy equation)
$$\begin{align} \underbrace{\frac{\partial k}{\partial t}}_{\text{time term}} + \underbrace{\overline{v}_j\frac{\partial k}{\partial x_j}}_{C^k} = &\underbrace{-\overline{v_i'v_j'} \frac{\partial \overline{v}_i}{\partial x_j}}_{P^k} \underbrace{- \frac{\partial }{\partial x_j}\left( \overline{v'_j\left( \frac{p'}{\rho} + \frac{1}{2}v_i'v_i\right) }\right)}_{D_t^k} + \underbrace{\nu \frac{\partial^2 k}{\partial x_j \partial x_j}}_{D_\nu^k} \underbrace{- g_i\beta\overline{v_i'\theta'}}_{G^k} \underbrace{- \nu\overline{\frac{\partial v_i'}{\partial x_j} \frac{\partial v_i'}{\partial x_j}}}_{\varepsilon} . \end{align}$$
The two comes from that $2\varepsilon$ is the total dissipation. The division by $3$ comes from that in 3D we will have three normal dissipation terms $\varepsilon_{11}$, $\varepsilon_{22}$, and $\varepsilon_{33}$ and because of their isotropic behavior they should all be equal.
I thought that since for a 2D problem we'll only have two normal dissipation terms $\varepsilon_{11}$ and $\varepsilon_{22}$ our model should be
$$\varepsilon_{ij} = \frac{2}{2}\varepsilon\delta_{ij} = \varepsilon_{ij}\delta_{ij},$$
but this is apparently wrong. The answer I got was that this is wrong because "the turbulent kinetic energy $k$ will still be calculated as in 3D when in 2D." That is
$$k = \overline{v_1'^2}+\overline{v_2'^2}+\overline{v_3'^2}.$$
One person explained it as even though we're in 2D there will still exist a $v_3'$ stress. This seems very weird to me. Why would you calculate $k$ as in 3D even when you're in 2D?
OBS! Note that tensor notation is used.
