In a hydrostatic transmission system, hydraulic pumps drive hydraulic motors (basically a reverse pump).
If you were use a smaller hydraulic pump as an input and a bigger hydraulic motor as the output, would it work like a reduction gearbox? Where the force is multiplied and the speed divided?
