I have a suicide shower head and even though the breaker is correctly sized it trips after about 6-8 minutes of showering.
1$\begingroup$ To answer the question "what in @#$% is a 'suicide shower head'": travel.stackexchange.com/questions/112085/… $\endgroup$– TimWescottApr 5 at 1:16
$\begingroup$ This may be a much better fit for diy.stackexchange.com. That's a home-improvement site, and if there's any plumbers or electricians from countries where these things are used, they may have a lot more insight into the actual practical "why" of it. $\endgroup$– TimWescottApr 5 at 1:18
$\begingroup$ Perhaps the "suicide" shower head is faulty. $\endgroup$– Solar MikeApr 5 at 5:41
$\begingroup$ Correctly sized how? Is the wire sized correctly? $\endgroup$– StainlessSteelRatApr 10 at 21:29
1 Answer
Circuit breakers trip because the current is too high or because they are faulty.
A clip-on ammeter will tell you which problem you have.
High amps could be a faulty heater, a partial short-circuit, or possibly too-small wires (you are heating up the wires).
$\begingroup$ Note: When the current is too high, or the breaker is faulty, "6-8 minutes" is normal behavior. Breaker design and specification includes provision to open after they heat up -- which may be 10 minutes, depending on how big the overload is. $\endgroup$– davidApr 7 at 0:29
$\begingroup$ Circuit breakers do not detect wire heating. The circuit breaker's amperage is selected so that it trips before the wire gets too hot. $\endgroup$ Apr 7 at 17:51
$\begingroup$ @TigerGuy Other way around. Wires with more amps get hot. $\endgroup$ Apr 10 at 0:49
$\begingroup$ @user253751 oaky, but an overloaded (undersize) wire will draw more amps. $\endgroup$ Apr 10 at 17:13
