Modern diesel engines have low compression ratio (some only 14:1, old diesel has 23:1), if compression ratio is directly connected to thermal efficency, how this engines achieve good efficency?
Can turbo boost compensate low compression ratio, is higher boost same as you have engine with higher compression ratio, in sense of efficinecy?
