A bolted end plate splice in a strut is designed to transmit compression by direct bearing of connecting cross-sections. If, after accounting for the bending moment due to strut action and additional moment due to moment amplification effects, the bolts themselves still experience no tension due to the large compressive force, is it possible to design the bolts to take only vertical shear?
How would the size of bolts affect the intended stiffness (underlined clause in red below) in the strut, assuming I provide the bare minimum to counter shear due to self-weight?
If you are answering with an example, you may use a 25m laced strut comprising of two numbers of UB914x305x287kg/m, taking a compression load of say 6000kN being spliced at a quarter span from each end support with 4 numbers of M20 bolts.
