I am designing a section of shaft that will hold a 1.25" wide sprocket. I found
The snap ring vendor states: Fits Groove Dia. 1.886 in Fits Groove Width 0.068 in
The snap ring has slightly smaller dimensions - obviously they are providing the tolerances for the grooves to be cut here, and the ring will be under slight tension once installed, hence the Free ID being smaller than the groove diameter.
Free I.D. - 1.85 in Thickness - 0.062 in
I am assuming that if I am mounting a component that is 1.25" wide, the distance between the grooves should be exactly 1.25" as seen below: myShaft
  • $\begingroup$ I have got the tolerances for the depth and width of the groove for a retaining ring that I picked out - it was listed on the manufacturers website; I think that since the groove is slightly wider than the thickness of the snap-ring that should be enough play. The groove width is 0.068 in and the snap ring thickness is 0.062 in $\endgroup$ Apr 2, 2023 at 0:54
I don't really know what you are trying to accomplish but from the description, I sure hope that sprocket has a bearing in it.
You really should get a micrometer and a piece of stock (like drill rod or a finely finished piece of square stock, etc) and close in on the stock and back off some known amount, and then slide and jiggle the stock to get a feel for different fits. Then you would know things like just how loose a clearance of 0.005 feels right up against the fit, and just how loose it feels when when amplified by a length of 4" away. It's not good to blindly design with numbers with no physical experience.
Well, no. Because your sprocket may not be exactly 1.25". You need to know the thickness tolerance of your sprocket and how tight a fit you want/need.
I don't know about aerospace requirements, but from my limited experience cutting grooves for retaining rings for regular stuff it doesn't seem critical. The ring doesn't seem to really need to be under tension in the radial direction. I recall many retaining rings for motors being quite loose on the shaft. I'm not actually sure whether the preferred scenario is to be under tension or to not be under tension. But for regular stuff, it seems that all you need is for t groove to not be so deep (i.e. the groove diameter to be so small) that the ring can sink deep enough to let something slide off. and for the width to not be so large that the ring can excessively tilt in the groove which would allow you to twist the ring off. They seem pretty idiot proof to me.
Look on McMaster Carr for retaining rings. They have recommended groove tolerances for different retaining rings you can draw from as well as the tolerances of the ring and grooves.
