I asked a different question a while back that led me to realize the hardest part of my project, position sensing. I had an idea and wanted to know if I'm trying to reinvent the wheel.
Specifically, I was considering the idea of a wheel orientation sensor that essentially is a circular PCB with copper channels going out from the center like bicycle spokes. And depending on which channel(s) completes the circuit, I know at least within a small degree of error, which I can figure out with math/trig, what direction my robot is pointed. At that point I might use a fine tune algorithm to further point it, which should be easy. The idea is to use this to orient a laser. I looked into potentiometers and I think the precision I need would cost way more than I'm willing to pay, if it even exists.
Two questions, am I reinventing the wheel? Is there some sensor I can buy that's already essentially this, and has a good amount of precision? If I design it myself, what are some good ways to sense which channel(s) are completing the circuit? I can think of various ways, but none are elegant and simple. (Edit - one way I dreamed up is a digital bus, with one value per-channel that gets sent to the bus if the channel completes. Not exactly sure how to design this off the top of my head but I think it's possible. I can design my own board and stuff if I need to)
This could be a really good solution for me, I think, because what I can do is use math to reduce the gearing to get more precision out of my sensor. In other words, if the sensor wheel spins a lot faster than the orientation wheel, I can use whatever ratio I want to increase the precision of the robot. This comes at the cost of more time spinning the motor of course, which is fine with me.
Can I make this work?
Edit: The precision I need is: as much as possible :). It's for a buddy's pool table as a ball placement device. I need to point at various 1mm spots about 3-5 feet away. I want no more than 2mm error, preferably 1mm.
Also, I am going to store and load positions of the robot, so this circular "wire potentiometer" (I guess that's a thing?) should help with that as well, especially if I can figure out an elegant solution to the channel detection problem.
13
  • $\begingroup$ What is "precise" ? Any idea of the change in angle to move 1" at 100 yards? $\endgroup$
    Apr 1, 2023 at 7:32
  • $\begingroup$ @SolarMike Answered with an edit, thanks for that, I should have been more precise with my question in the first place $\endgroup$
    – neural
    Apr 1, 2023 at 8:05
  • $\begingroup$ So, how does your 1mm at 5 feet translate into an angle? +/- 5 degrees? 1 degree? 30 seconds? 4 seconds? $\endgroup$
    Apr 1, 2023 at 8:17
  • $\begingroup$ OK, my math is a little rusty, but the answer I came up with is (degrees): 0.02221896082497133662762253845753 (and yes, that's the correct order of magnitude) $\endgroup$
    – neural
    Apr 1, 2023 at 8:50
  • $\begingroup$ So how big is your circular pcb and how many channels? What resolution will you get? Close to your 0.02 degree? $\endgroup$
    Apr 1, 2023 at 8:52
@AJN answered my question. I think a wheel encoder and gear ratios can get me the precision I need.
I can calibrate it by pointing it at a spot manually, and then use wheel encoders on two axes to detect the number of turns. This plus gear ratios and math should give me the precision I need to automatically position the laser. I'm excited about this idea, it's simple and doable.
If @AJN would like to post an answer for credit I will mark it.
  • $\begingroup$ Be aware that gears exhibit backlash. $\endgroup$
    – Transistor
    Apr 1, 2023 at 9:45
  • $\begingroup$ @Transistor - thanks, yeah, I need good gearing most likely. I'll figure out in the POC if it works or not, I can measure the output using string, etc. $\endgroup$
    – neural
    Apr 2, 2023 at 2:08
Current drone technology appears to have this problem well sorted. It includes motion sensors and GPS. You should be able to find a package solution in that rabbit-hole. PS 1" @ 100yards is approximately 1 minute of angle.
  • $\begingroup$ Hmm, are there any packages you can recommend? I've looked around a bit but I probably don't know what to be looking for. I'm open to the idea for sure though, anything to save a lot of work of designing my own thing. $\endgroup$
    – neural
    Apr 17, 2023 at 20:33
