If there are heavy components mounted on it, what will happen? I think it accelerates very slowly, but reaches at the highest RPM at the end because torque is equal to angular acceleration * moment inertia.
Am I correct?
Sign up to join this communityIf there are heavy components mounted on it, what will happen? I think it accelerates very slowly, but reaches at the highest RPM at the end because torque is equal to angular acceleration * moment inertia.
Am I correct?
As long as the torque is greater than any of the resistances the shaft is experiencing, then yes.
All else being equal, yes.
However
Real imbalances will tend to be bigger, or need more labor to bring them down to some fixed value. Power loss due to vibration will tend to be proportional to the absolute value of the imbalance, not to the proportion of the thing's mass.
Bearings that can support something heavy will tend toward greater drag than bearings that can only support something light.
So in real life, having a big heavy "thing" will have greater losses, and will be harder to spin. Or the amount of effort -- and thus expense -- that needs to be put into getting those losses down will be greater.
