As I am examining the components of a Caterpillar 323D hydraulic excavator, I would like to inquire about the specifics of its diesel engine. Can you provide information on the number of pistons and strokes in the engine? Additionally, could you explain how the engine is connected to the multiple pumps?
  • $\begingroup$ Rexroth have pumps that are designed to bolt together. $\endgroup$
    Mar 17 at 14:28
  • $\begingroup$ What are the first 3 digits of the serial number? $\endgroup$ Mar 18 at 3:01
The Caterpillar 323D hydraulic excavator is powered by a Cat C7.1 ACERT engine. The engine specifications are as follows:
  • Engine Model: Cat C7.1 ACERT (Inline 6-cylinder)
  • Net Power (ISO 9249): 149 hp (110 kW)
  • Displacement: 7.1 L
  • Maximum Torque (SAE J1995): 502 lb-ft (681 Nm) at 1500 rpm
  • Emissions: EPA Tier 2 / EU Stage II equivalent
The hydraulic system in the Caterpillar 323D uses two main variable-displacement axial piston pumps, along with one gear pump for the pilot system. These pumps provide hydraulic fluid flow for the machine's operation, including the boom, stick, bucket, swing, and travel functions.
The hydraulic pumps are mechanically coupled to the engine using a damper flex plate. The damper flex plate acts as a flexible coupling that connects the engine output shaft to the hydraulic pump input shaft. It absorbs torsional vibrations and shock loads, allowing for smoother operation and reducing wear on the hydraulic pump and engine components.
Source
Caterpillar Performance Handbook, Edition 46
  • $\begingroup$ How does single engine is connected to 2 pumps in the excavator? $\endgroup$
    – Prerna
    Mar 21 at 5:24
    $\begingroup$ @Prerna they are usually bolted. $\endgroup$
    Mar 21 at 7:44
  • $\begingroup$ The pumps are stacked and bolted together and share the same shaft $\endgroup$ Mar 21 at 14:35
This is a great course to follow if you are interested in the subject of hydraulic power.
https://www.coursera.org/lecture/fluid-power/hydraulics-and-pneumatics-SD8dv
Do you have a specific engine in mind? Most diesel engines are 4 stroke, if you have a specific engine in mind you will be able to know how many pistons it has. If you are looking for a suitable engine then you will find it it depends on the required loads, If I were to guess I would say that you have multiple pumps on a single axle that are coupled to an engine. The hydraulic controls determine the amount of torque or load transmitted to the engine.
I hope that helps.
