I am trying to understand how to describe and calculate the shape a length of piano wire makes from its own weight when supported vertically at only one end. Is it a catenary or a parabola? Specifically I am trying to calculate how long a piece of piano wire I would need to have it arc exactly 180 degrees to contact the same plane to which it is attached, and the distance from the attachment point and this unattached contact point.
How would this equation differ for a thin strip of spring steel? Simply using different Young's modulus and Poisson ratios for x and y components?
BTW, this isn't a student homework problem, I am a machinist making a strange apparatus for a science museum, and trying to push beyond empirical solutions to these kinds of problems. I'm sure there is a very broadly applicable deformation equation which could be applied here, but I don't know what to search for.
Thanks in advance!
