FEA engine
I'm using CCX finite elements analysis engine along with its pre- and post-processor CGX:
http://www.dhondt.de/index.html
Example
I'm looking at one example here that is using steel material:
Elastic specifications
In the example above, the declaration is done for Young’s modulus, Poisson’s ratio, and Temperature:
*ELASTIC,TYPE=ISO
210000,0.333333333,0
Density
Mass density is initialized by:
*DENSITY
7.85e-9
Gravity
Gravity, i.e. acceleration vector, is defined like this:
*DLOAD
Eall,GRAV,9810.,0.,-2,0.
Input values
Therefore, the input values are:
- Young’s modulus =
210000
- Mass density =
7.85e-9
- Gravity acceleration =
9810.
Question
What are the units of measurement for the above example?
My guess
I know the gravity acceleration is 9.8 m/s2
. So, 9810.
means mm/s2
But I'm confused about Young’s modulus and Mass density. What are their units? They should be consistent with the mm
. But I cannot figure them out.
Solved
This table from the latest CalculiX solver documentation helps with unit conversion. The units of the above example are mm,N,s,K
