Can anyone give me some guidance with this question? I'm finding it a bit difficult.How is the object suppose to look like?enter image description here
    $\begingroup$ think about this ... the short vertical line in the middle of the first diagram ... what does it represent? $\endgroup$
    – jsotola
    Feb 27 at 1:17
  • $\begingroup$ This may give you a hint: engineering.stackexchange.com/a/28582/10902 $\endgroup$
    Feb 27 at 5:03
  • $\begingroup$ Think which line is the dashed line and which line is the vertical and it should become obvious. Good test question though, you either know how to do it or not. $\endgroup$
    – joojaa
    Feb 27 at 5:44
  • $\begingroup$ another trick ... turn the page upside down $\endgroup$
    – jsotola
    Feb 27 at 6:11
  • $\begingroup$ In the top view, how do you know where point S is? To me it should be the tip of semi circle (quadrant) but the location of the letter S in that view does not seem to support that. I am making my assumption based on the elevation view. $\endgroup$
    – Forward Ed
    Feb 27 at 11:34
