I changed out of curiosity the max speed variable of my car ECU from 250Km/h to 60Km/h to see if the car reach that speed and hold there or I can go beyond and get a warning but it turns out that I cannot exceed that limit.
Now, I'm unable to get the speed to its original value nor increase it, I found out later that this particular variable can only be decreased... My local car dealer (VW) doesn't know how to fix it, so I had to rely on third party mechanics specialized in ECUs but unfortunately so far no one have figured out the solution, even after re-flashing the entire ECU.
I got the reference of my ECU chip which is UN92CB but I couldn't find any datasheet, so I was wondering if it is possible to hardware lock a variable from increasing, so I can just buy a new ECU instead of losing my time figuring out the problem.
Edit: Unfortunately I don't know where or in which chip it's stored and I don't have the necessary tools to dig in the binary program, the ECU specialist have very expensive equipment but a small brain, I already asked him to backup the program inside my ECU, reduce the speed limit to 59Km/h for example, and re-flash it again with the backup file, if the speed limit stays at 59Km/h then it would be pointless to continue with this method and we should look elsewhere.
Anyway, my local VW dealer doesn't know anything, there are no ways to directly contact VW Germany, and the ECU architecture is most likely a manufacturer secret.
There is still hope someone managed to overcome the issue by flashing it again in this thread, btw I removed the car speed sensor so I can accelerate as much as I want :)
