There is a tube travelling horizontally, 8m below the ground, with a diameter 15cm. It then turns upwards and at a height of 1.75m above the ground, it shoots water out with a velocity 32 m/s. Find the pressure inside pipe.
Consider water to be an ideal fluid. (This is a high school level question) enter image description here]
    $\begingroup$ You know what the pressure is at Point 2 so you can plug that into the equation you have below. You should also double check your area equation. $\endgroup$
    – J. Ari
    Feb 16 at 20:13
My attempt at solving the question
This is my attempt. I'm struggling to find a second relation between the pressures.
