I have a eigenfrequency simulation $ M * \ddot{\vec{x}} + K * \vec{x} = \vec{0} $ and want to add point masses to certain nodes. The only example I have is a 1D matrix where all of the mass at node 1 is added to the x1/x1 element in the matrix.
Since my matrix has 3 main diagonal elements at node 1, x1/x1, y1/y1 and z1/z1, do I add 1/3 at each of these?
I first added the entire mass (which makes sense because if I only move in x direction, I still need to move the whole mass) but then the sum of all masses in the matrix is not consistent with the mass of the system. Which way is correct?
