Like a directional valve but used to select either pair of supply and return. Could be done with two regular 5/3 valves, but it would be nice to use only a single valve. Does something like it exist?
11
  • $\begingroup$ Yes. But a simple search on the internet with the exact same words as your question would yield results. $\endgroup$
    – NMech
    Jan 26 at 15:32
  • $\begingroup$ NMech I did. But clearly you didn't, or you misunderstood the question. $\endgroup$
    – K0ICHI
    Jan 26 at 16:02
  • $\begingroup$ Search on manufacturers like Bosch Rexroth - they make valves like this. $\endgroup$
    Jan 26 at 16:21
  • $\begingroup$ @SolarMike Which search term do you suggest I use? $\endgroup$
    – K0ICHI
    Jan 26 at 16:31
    $\begingroup$ look at MHS $\endgroup$
    – NMech
    Jan 26 at 18:42
