Have a look at this water wheel (located at Hama, Syria).
Most spoked wheels seem to be designed with spokes that radiate outward from the center of the hub (bicycle wheels being the notable exception). All of the spokes in this wheel are offset from the center of rotation.
Is there a good reason for this? it seems to add extra levels of complexity for no added benefit (that I can see). Ancient water wheel
    $\begingroup$ Because the centre is a square. $\endgroup$
    Jan 19, 2023 at 9:46
  • 3
    $\begingroup$ Does it really add extra levels of complexity? I would intuitively say that this is easier to build than a hub that can take 20 spokes in the center, especially without modern machinery. $\endgroup$ Jan 19, 2023 at 9:47
  • $\begingroup$ @OpticalResonator - isn't it simpler to build a wheel if all the spokes are the same length? $\endgroup$ Jan 19, 2023 at 12:46
  • $\begingroup$ You have a limited reference to simpler. The spokes are not metal, but wood and attaching to wood takes up space, so instead of an area where 24 spokes meet, spokes are split into 4 groups that follow a pattern, allowing easier and larger support. $\endgroup$ Jan 19, 2023 at 17:08
Radial lacing "tortures" the spokes of the wheel because when torque needs to be transferred from the hub to the ring when accelerating (or from ther ring to the hub during braking).
Radial no load Radial with torque
enter image description here enter image description here
I.e. if radial lacing is used then the spokes would need to act as beams transferring a bending moment (but their second moment of area is really small so they would deform and result in a pattern similar to cross lacing).
The Different patterns of lacing (Two cross, 3 cross etc), by having an offset from the center of the wheel, they allow the carrying elements to act more ("more" is the essential word here) as rods (elements carrying only axial forces). (The cross parameter improves the geometric stability of the pattern).
Different lacing patterns Figure: Different lacing patterns (source: best wheel set)
That is the reason that probably this watermill has this shape (although most surviving watermills are designed by wood beams with enough cross-section that gives them a second moment of area that doesn't allow much deformation). However, the wooden beams are in stark contrast to the spokes of a bicycle wheel in terms of second moment of area.
