Say we have ten cameras surrounding an object. The object changes its color with a certain frequency (or any information other than color, such as a text on it). The point is if all cameras are triggered simultaneously, they will capture their frame such that the object in all those frames has the same color in it (or the same text or information).
For example, if the text on the object changes with a frequency of 1 Hz, it is obviously possible that we trigger the cameras at the same time and see the same text in all frames. However, if the frequency of the change of that text on the object changes, my question is to what realistic extent can we obtain the same information/text from all frames.
P.S., An additional question would be if this possiblity would hold if the trigger is made wireless (assuming all the cameras have the same distance from the wireless transmitter).
---edit:
All cameras look at a set of LEDs (3 or 4 ones) which are very small but their intensity can be controlled by myself so exposure time can be small (should be very small). But the LEDs move/vibrate and my goal is that the frames basically are from the same position instance. My other intuitive example is if a text is changing with high frequency and all frames have the same text if taken simoultaneously.
