I have a task to choose a material and gear module for a double step up gearbox with equal ratios
The first pinion has a max bending stress of 296 MPa and the gear has 239 MPa. The permissible being stress for my material is 345 MPa. So both are acceptable for my chosen material. But how do I consider the factor of safety in my choice and work it out?
