I make specialized flapper valves that are similar to O-Rings. The current model uses aluminum sheets as base disks that adhere to the rubber (2 part urethane). The rubber is poured into the waxed mold and then topped with an aluminum piece. Unfortunately, there is currently no way to remove the rubber from the mold without damaging the mold or rubber material.
The mixing, degassing, pouring, and subsequent removal of the rubber must be done perfectly in order to create a seal. Since this process is done almost entirely by hand, there is a large margin of error and I end up with a lot of waste. Not only that, but I spend an extensive amount of time cleaning the mold to remove even the specks of dust. Also, I believe the aluminum piece may be preventing the rubber from moving easily making it more difficult to get a good seal with even the slightest imperfection. I should also note that the center hole is what gets worn away the fastest and is my most common issue with age.
Previous thoughts have been to weld handles to the aluminum pieces to make removal easier. However, welding would warp the aluminum. Another idea was to put screws through the aluminum but this would result in a rubber piece with holes/tears. A different idea was to remove the aluminum entirely and make the rubber much thicker. The center hole would still need to be reinforced though and this method may reduce the life of the flapper valve. Current implementation has added "ears" to the edge of the aluminum but as these sit flush against the mold, they are still near impossible to remove without damaging the mold.
I am not an engineer nor am I familiar with this type of work so pointing me in the right direction, any thoughts, and any comments are appreciated; thank you!
