If we a M12 bolt what will the relation between the major diameter and the hexagon diameter be? If we calculate it geometrically it should be $E(Hexagon\space diameter)=\sqrt{3}d(major \space diameter)$ is this correct or other factors are taken in?
  • $\begingroup$ If you test your expression against the dimensions of an M4 nut, what is the result? Correct? And M8? $\endgroup$
    Dec 27, 2022 at 18:09
A quick check gives the following:
Size Thread d √3d Nut Error
M5 5 8.66 8 8.25%
M6 6 10.39 10 3.9%
M8 8 13.86 13 6.62%
M10 10 17.32 17 1.88%
M12 12 20.78 19 9.37%
M16 16 27.71 24 15.46%
M20 20 34.64 30 15.47%
M24 24 41.57 36 15.47%
M30 30 51.96 46 12.96%
