I'm building a kitchen/bar in my unused basement area, and want to incorporate my 180 gallon saltwater aquarium into the design.
Before I decide on a design, I wanted to ask for advice/opinions on viability of this design.
I have never welded, and have other metal-working projects I want to take on, so before I purchase equipment, I wanted to get advice on this project as well. Moving forward, I'd like to work with aluminum so part of my question is what materials can/should I use if this design is sound.
Thing it needs to hold:
- This will weigh roughly 2000lbs when filled.
Design:
- Is this design strong enough to hold the weight of tank?
- Can this design be simplified?
- What materials should I use?
Intended Usage:
- The usage is to be mounted above a countertop in the kitchen area
- Safety is obviously a concern, this will be suspended above a work space. I want to know that both the inhabitants of the tank, and the inhabitants of the house are safe.
- This can be mounted directly into the basement walls and floor, both of which are concrete.
