I'd like to produce prototype parts by molding a silicon sheet (0.6mm thickness) to a shape that looks roughly like below:
If split in two, this part looks like this:
I have attempted to print this part with a couple of 3d printers using flex resins, but without much success at maintaining a decent accuracy on the thickness. I have also tried to make 3d-printed molds for liquid silicone but getting working parts out of these molds proved a real challenge (I suck a degasing, and these parts have really thin walls).
So, I am looking in buying a flat 0.6mm silicone sheet with fairly accurate constant thickness and then mold it with a vacuum bag under controlled temperature. A couple of questions before I go down that path:
is the general idea sound ? (shaping an existing flat sheet of silicone). I am asking because I can't find any youtube video of people who produce parts like this and everyone knows that if it does not exist on youtube, it does not exist. i.e., I can't make myself believe that no one has done that or documented that before.
Is temperature needed ? (would a vacuum bag be sufficient to mold a sheet ?) If not, how much temperature (compared to the specified max temperature of the silicon sheet) ?
Should I try an outer mold or an inner mold ?
