Tin Whiskers are a major problem in the design of electronic circuits and the manufacturing of electronic hardware.
What are Tin Whiskers? How can electronic products be design to mitigate the issue of Tin Whiskers?
References:
Sign up to join this communityTin Whiskers are a major problem in the design of electronic circuits and the manufacturing of electronic hardware.
References:
What are tin whiskers?
The easy explanation is that Tin Whiskers are tiny threads of tin that grow out of lead-free tin soldier. They are a problem because they can cause electrical shorts at random times. They can begin to grow from weeks to years after a part is produced.
The exact causes of tin whiskers are not known, but their growth seems to be caused by internal stresses in the tin that work to push out the thin whiskers. Since the issues are caused by the internal structure of the tin, analyzing the basic material properties is hard.
Tin is not the only material that has whiskers. Metallic whiskers have also been researched in zinc, cadmium, indium, silver, aluminum, and gold.
How to mitigate tin whiskers?
From this article from EE Times and this article from Electronics Design, the following are strategies in order of mitigating the root cause to mitigating the effects:
