Here's a close up:
This vehicle license-plate holder uses three of them: Unfortunately I can't see behind.
Note, ignore the four small dimples on the plastic arranged rectangularly; unrelated.
What is this strange fastener and how to remove it ?
I've had screwdrivers with "tri tips" (for example, there are true tri-tip screws on a Nintendo Switch game console) but this looks different...
  • $\begingroup$ ask the auto dealer service department $\endgroup$
    – jsotola
    Dec 2, 2022 at 0:29
  • $\begingroup$ Regardless of what it is, you can drill it out $\endgroup$
    – Abel
    Dec 2, 2022 at 1:01
  • $\begingroup$ it's probably a pin ... hook something under the head and pull it out $\endgroup$
    – jsotola
    Dec 2, 2022 at 1:21
  • $\begingroup$ @jsotola - ah that simple?! TBC by head you mean the "brassy colored part" ... ? $\endgroup$
    – Fattie
    Dec 2, 2022 at 10:40
  • $\begingroup$ yes ... it's only a guess though $\endgroup$
    – jsotola
    Dec 2, 2022 at 15:14
I would think that is one of those wide headed fixings with 3 "ears" that expand when the central pin is pushed in.
Usually, to remove, you push the pin all the way through and then you can pull that fixing out as the "ears" then can collapse towards the axial centre as the pin is no longer there.
If you do a search for"trim fixing clips" you will see a variety around that theme I described.
  • $\begingroup$ brilliant! you'd think ... there'd be a special rivet-removing tool ? By push through, you mean, if I stick something in there I'll feel something - and that's the thing to push through? $\endgroup$
    – Fattie
    Dec 2, 2022 at 10:39
Solar Mike is right, this is a rivet and the only way to remove it is to pull really hard on the plastic surrounding it, or wedge a screwdriver blade under the plastic part and pry it loose from the hole in the sheet metal into which the rivet was pressed.
  • $\begingroup$ Got it, damn, the problem here is - it's plastic on plastic. (the plate-holder-thing is plastic and the bumper itself is plastic) any sort of pull/wedging will result in disaster! $\endgroup$
    – Fattie
  • $\begingroup$ Well then, you gotta DRILL, BABY! DRILL! $\endgroup$ Dec 2, 2022 at 18:08
  • $\begingroup$ got it. just any old (maybe "for metal") drill bit of not-too-much-bigger? $\endgroup$
    – Fattie
    Dec 2, 2022 at 18:27
  • $\begingroup$ also .. mechanics.stackexchange.com/a/90455/36606 $\endgroup$
    – Fattie
    Dec 2, 2022 at 18:28
