17
Something hit me during my last flight: our ears feel that the pressure around us changes quickly during liftoff and landing, they hurt more and more until we make them pop. However, the cabin must maintain a level of oxygen higher than outside the aircraft because it isn't dense enough at ~10km to breathe normally.
Does that mean that the aircraft merely takes air from the outside, heats it up (it's around -40°C outside at 10km) and adds oxygen to it before blowing it inside? How else?
19
Because the cabin isn't pressurized to sea level pressure instead it to about 8k ft equivalent. (while the plane is 4.5 times higher)
This means there is less differential pressure than if the cabin was pressurized to sea level pressure. But it's still within the limit of what passengers feel comfortable with.
This answer on aviation.SE contains a plot of cabin pressure over time during a flight:
Cabin pressure over time
Source
The composition of air doesn't change with altitude just the pressure. This means that you only need to compress the air before blowing it in.
    $\begingroup$ Note as well that just before take-off, as the engines ramp up (as the engines do the compression of the cabin as well as flying), that you exceed normal air pressure for several minutes before the flight begins. That's why you begin to feel pressure even before the plan takes off. $\endgroup$
    – Mark
    Sep 6, 2015 at 18:18
  • $\begingroup$ @Mark that can be accounted for by adjusting the outflow valves, though it's helpful for a quick test of the seals on the ground. $\endgroup$ Sep 6, 2015 at 20:53
  • $\begingroup$ Crystal clear, thanks very much. I am aware the composition of air doesn't change with altitude, I should have known compressing the outside air was easier than adding O2 to it (which, thinking about it, is also compressing it). Solved! $\endgroup$ Sep 6, 2015 at 22:05
  • $\begingroup$ The evil suppressed zero graph strikes again! :-) $\endgroup$ Sep 7, 2015 at 14:47
There's a difference between being pressurized to an absolute value and being pressurized to a relative value.
For instance, if the cabin immediately pressurized to the same atmospheric pressure as your departure terminal, then your ears would not pop on ascent, but they would have to pop at some point on the descent unless the elevation of the landing terminal were the same as the departure.
This would also mean that the aircraft structure would have to be thick enough to withstand the full differential pressure between up to sea level and cruising altitude.
If instead the cabin only pressurized to, say, 7psi (about 50kPa?) above whatever the outside pressure is, then there's no need for an elaborate destination pressure matching scheme and the aircraft walls can be made thinner, thus lighter and more fuel efficient.
Relative pressurization means the absolute pressure changes with altitude, so your ears pop.
