I need to find profile view of an drawing when I have frontal and top views.
$\begingroup$ @Transistor, I updated and added photo of what I've done so far. $\endgroup$– autocadnewbie46Oct 28, 2022 at 8:20
$\begingroup$ So what about the base? $\endgroup$– Solar MikeOct 28, 2022 at 8:39
$\begingroup$ 1) All you've done is create the construction lines that will allow you to finish. 2) What exactly is your question? $\endgroup$– FredOct 28, 2022 at 9:16
$\begingroup$ I need help in finishing the profile view and i'm not sure if I used correct lines $\endgroup$– autocadnewbie46Oct 28, 2022 at 9:17
$\begingroup$ Apply solid lines to all the lines visible from the new viewpoint. Apply dashed lines to the hidden lines. $\endgroup$– TransistorOct 28, 2022 at 10:43
Show 2 more comments
