Given a volute pump casing, the impeller, and RPM how would one obtain a simulated head-flow graph? As for what I have seen in research papers most methods already assume input flowrate / pressure and even output head. However, in my case I do not know the inlet flowrate. It is determined by the impeller itself, right?
What I'm asking for is a globally outlined procedure of how such a problem could be solved. Mainly, what should be assumed and what will be simulated.
The pump has an inlet hose into a water reservoir (say h meters below inlet) and is fully primed/submerged in water. RPM is known as well as are the CAD models of pump and impeller.
