Can anyone please explain the reason for above question?
  • $\begingroup$ Requirement is that the coolant be significantly cooler than what you wish to cool. This difference drives heat to the coolant. What form does this air take at that temperature and high enough pressure to pump it? Probably not entirely gas anymore... $\endgroup$
    – Abel
    Sep 17, 2022 at 7:34
  • $\begingroup$ The question is probably asked to find out what the person who is asked the question knows about the gases, cooling of the system and constraints. $\endgroup$
    Sep 17, 2022 at 8:25
  • $\begingroup$ Certainly could use clarification. Could be a translation/language issue where the word "reason" in the context of a "why" question should be interpreted as "answer" $\endgroup$
    – Abel
    Sep 17, 2022 at 12:36
Refrigerant systems that uses boiling and condensing (like CO2 and regular Freon systems) require a single refrigerant because otherwise you have multiple boiling/consensing temperatures/pressures. Air is mostly nitrogen and oxygen, which have different boiling points.
