I have been trying to make a surface loft of a pipe that goes around a U-turn and gradually changes diameter.
I was finally able to complete the surface loft, but something is off in the result. My profile and guide curves are shown below. As you can see, the profiles are gradually spaced circles coincident to the guide U-curve. It is hard to see in this image, but when I zoom in on the larger diameter pipe, you can see that it is no longer straight like the guide curve.
I've highlighted the portions with low curvature, and while this is a problem, there is a portion on the opposite side with very high curvature. How do I ensure this surface loft in the straight portions of the guide is also straight?
I'm using Solidworks v.22.
curves problem_loft
  • $\begingroup$ The simple answer to this, is add more guide curves. $\endgroup$ Sep 16, 2022 at 12:21
  • $\begingroup$ For this specific shape, however, it might be more effective to model the tapered tube in its unbent state using a revolve, and then use the Flex feature to bend it around $\endgroup$ Sep 16, 2022 at 12:22
  • $\begingroup$ I wasn't aware I could add more than one guide curve. $\endgroup$
    – WnGatRC456
    Sep 16, 2022 at 17:20
For the shape that you are attempting to create - it would be more effective to model the tapered tube in its unbent state using a revolve, and then use the Flex feature to bend it around.
Finished Item
  • $\begingroup$ What is the flex tool? And did you simply make two shells for the straight portions? $\endgroup$
    – WnGatRC456
    Sep 16, 2022 at 17:13
  • $\begingroup$ I'm not clear on the procedure. Do I make a revolution and then use another tool to change it? $\endgroup$
    – WnGatRC456
    Sep 16, 2022 at 17:19
  • $\begingroup$ Yes - look up flex in the help! I'm not at my computer to add details to this answer sorry. $\endgroup$ Sep 17, 2022 at 7:21
  • $\begingroup$ I found a lot of less-than-useful information and blurry youtube videos. If you could update your answer with a video showing how you designed this I can follow the same process you did. $\endgroup$
    – WnGatRC456
    Sep 17, 2022 at 12:50
  • $\begingroup$ By "the help" I meant here: help.solidworks.com/2021/English/SolidWorks/sldworks/… $\endgroup$ Sep 18, 2022 at 10:38
