So in this video(https://www.youtube.com/watch?v=v1z829NF9PA) at around 2:35 it says that the alluminium ingots for alluminium foil, after being heated, are cooled down with a mixture of 95% water, 5% oil. Why not simply use 100% water? Because I looked it up online and it seems most oils have a lower specific heat than water, so would be worse for cooling. Is it that oil is somehow cheaper, or some other reason? This episode was in 2001 btw, on Jan 6(so before 9/11)
Thanks
