I need to submit a lab report. I've measured:
  • Differential pressure [Volts]
  • Flow rate [Hz]
  • Flow Rate [m^3/s]
In my report I need to get the Pressure Differential in Pascal but how can I convert Volts to Pascal?(?!?!?!?!?!)
How do the measuring devices can measure pressure in volts and flow rate in Hz in the first place?
Thank you!
Image for demonstration: enter image description here
  • $\begingroup$ Calibrate the sensors against known values of pressure - the lab has a barometer etc $\endgroup$
    Commented Aug 19, 2022 at 20:20
The device will contain a pressure transducer.
transducer
noun
a device that converts variations in a physical quantity, such as pressure or brightness, into an electrical signal, or vice versa.
In your case it is converting pressure into a voltage.
... but how can I convert Volts to Pascal?
You read the manual for the device and find the conversion factor which will be in volts/pascal or pascal/volt. (Note lowercase for SI units named after a person. The symbols are capitalised.)
