You could calculate the velocity magnitude from total energy (gravitational and kinetic) of the comet, which must be constant:
$$E = E_p+E_k = -\frac{G\cdot M\cdot m}{r_A}+\frac{1}{2}m\cdot v_A^2 = -\frac{G\cdot M\cdot m}{r_B}+\frac{1}{2}m\cdot v_B^2$$
From that, the velocity magnitude $v_B$ at point B is:
$$v_B = \sqrt{v_A^2-2\cdot G\cdot M\cdot \frac{r_B-r_A}{r_A\cdot r_B}}$$
(You will need gravitational constant $G$ and mass of the Sun $M$.)
For the velocity components, you can use second Keplers law, which states that area velocity $\vec{A}$ is constant:
$$\vec{A} = \vec{r}_A \times \vec{v}_A = \vec{r}_B \times \vec{v}_B$$
From that, area velocity magnitude can be expressed as:
$$A = r_A\cdot v_A \cdot \sin(\alpha) = r_B\cdot v_B \cdot \sin(\beta)$$
Since $\alpha$ is 90°, the angle $\beta$ between position vector $\vec{r}_B$ and velocity vector $\vec{v}_B$ will be:
$$\beta = \arcsin\left(\frac{r_A\cdot v_A}{r_B\cdot v_B}\right)$$
Now the radial and transverse velocity components at point B are:
$$\vec{v}_B = \left(v_B\cdot \cos(\beta), v_B\cdot \sin(\beta)\right)$$
(Technically there are two points B, so this is only one of the two solutions, but I think you can easily work out the second one if needed.)
23.80 mi/s
? $\endgroup$
