I have a problem with my Tool Palettes. Currently tried several methods, which unfortunately didn't bring the desired result. The situation looks as follows:
After loading the palette from the file (.acx extension) I have just a blank box instead of a proper signature. Moreover, I don't know why my Tool Properties are inactive. Therefore I can't use this option at all:
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoCAD-LT/files/GUID-021B36D2-5009-43FE-A78C-E4BE8EED0960-htm.html
I have got AutoCAD LT 2020, so after trying the following options:
  1. Finding the following address and putting the .acx palettes there: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-import-tool-palette-atc-files-into-AutoCAD-Plant-3D.html
  2. Customizing the interface as shown here https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Palettes-will-not-display-in-AutoCAD.html https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Palettes-will-not-display-in-AutoCAD.html
  3. Manual export & import layers didn't help
Could anyone advise what to do? I am quite fresh user to AutoCAD
I believe what you seek is called a "Profile" and can be exported/imported as a .arg file.
File->Options then Profiles tab.
My recollection may be outdated, but they likely still call it a "Profile"
Your palette is locked for writing. See the padlock at the bottom. Most probably this is because the files/folders are set as read only in your operating system.
Can't tell why your icons are not displayed properly though
