I recently had a discussion about design factors and design uncertainty. Looking in Shigley's Mechanical Engineering Design, pg. 17, ed. 3, there is a detailed discussion of this topic. The authors define the design factor as follows.
$$ n_d = \frac{\text{loss of function parameter}}{\text{maximum allowable parameter}} $$
Where $n_d$ is the design factor.
This is as I would expect. However, they then present the following example calculation.
Consider that the maximum load on a structure is known with an uncertainty of $\pm 20\%$, and the load causing failure is known within $\pm 15\%$. If the load causing failure is nominally $10\text{kN}$, determine the design factor and the maximum allowable load that will offset the absolute uncertainties.
They state that, in this instance, the design factor can be calculated as follows.
$$ n_d = \frac{1/0.85}{1/{1.2}} $$
As I understand it, this is inconsistent with their original definition. The original definition is a ratio between the absolute values of the given parameter for failure and use (adjusted for uncertainty). This isn't the same as the second definition, which is a ratio between the percentage uncertainties themselves.
Is this a mistake, or do I misunderstand something?
