The context
I was reading this article in Arxiv "The OpenPicoAmp : an open-source planar lipid bilayer amplifier for hands-on learning of neuroscience" (PDF available here) and found two diagrams.
I know the type of diagrams for (B) are called "circuit diagrams", but I don't know what's the name for the type of diagram of (A). Both (A) and (B) use a buffer amplifier, but I wonder if there's a common name for the type of diagram of (A).
The question
Is there a common name for the type of diagram of (A)? If not, what's the name of the blue part called? (If I recall correctly, the red part is called "buffer amplifier")
  • $\begingroup$ a cross section? $\endgroup$
    – Abel
    Jul 28, 2022 at 2:06
    $\begingroup$ Both A & B are circuit diagrams. The difference is that "B" is a closed loop circuit, while the circuit of "A" is connected through the liquid conductor. $\endgroup$
    – r13
    Jul 28, 2022 at 2:34
    $\begingroup$ neither are called graphs. A is a circuit diagram with details $\endgroup$
    – Tiger Guy
    Jul 28, 2022 at 3:13
    $\begingroup$ Figure B would typically be called a schematic diagram. $\endgroup$ Jul 28, 2022 at 12:48
The type of diagram in blue is a "pictorial diagram" or "pictorial circuit diagram." Figure A a combination of a pictorial diagram and a "schematic diagram" or "schematic circuit diagram."
The part shown in figure A is referred to in the paper as a "bilayer chamber." It is a experimental apparatus used to measure the electrical properties of a lipid bilayer. It is not a standard component so there is no standard schematic diagram element for it. The component behaves similarly to a resistor and a capacitor in parallel, so the authors draw it that way in figure B.
